Because of a problem I'm having in another thread, I want to build my own THC basically. Or more simply put, I want to control a servo motor separately.
I want to disconnect the Z axis servo motor from my CNC table setup, and somehow control it completely separately.
That's basically what I'm doing now since I don't have ATHC. I just sit on a chair with a welding helmet on and watch the spark cutting, bringing the head up and down by eye. I'm completely used to it by now and I don't use it enough to upgrade to a new system.
So how can I manually control this servo motor to go up and down? It has the power cable coming out of it, which is easy to get to, and it has a RJ45 connector going into it at the encoder. Here's a pic:
What do I need to do to make that happen?
How to control a servo motor?
- Scratch
Re: How to control a servo motor?
Google the manufacturing Company and model of the servo for wiring diagram or other info.
Not sure we're understanding you. You say you bring the head up and down while watching the cut. Are you doing this with a controller or physically doing it with your hands? If you're doing it with a controller, aren't you already manually moving it up and down?
Regardless, all motors (stepper, servo, etc) are driven by a driver and controlled by a controller. Depending on the configuration, the driver turns the motor a specific amount of degrees based on the step signal/pulse from the controller.
