USN 2 layer 5 piece Commerative / Memorial with Candy Finish
Completed this a while back using an anchor image from here as the base to start with. This is two layer, 5 piece, painted candy Gold and Blue and finished with 2k Clear. Held together by Super Magnets. This was presented at his retirement and went over quite well. Hopefully someone will be able to convert this to DXF in case anyone needs it. I ran into no issues in Design Edge but it seems that converting to DXF results in some anomalies.
- little blue choo
Re: USN 2 layer 5 piece Commerative / Memorial with Candy Finish
Looks Great
Rick
Rick
Rick
Arclight 9600 4x8 table
- Specialkfab
How do the magnets work. Do you orientate the pieces then apply the magnets on the back to hold together?
DHC2 PlasmaCam 4X4
Pipe Attachment
HyperTherm 45XP
Pipe Attachment
HyperTherm 45XP
They work great. I just throw them on strategically. Like on this one I placed them on back of the ring with lettering and the USN and then assemble. No glue or anything like that however I have used JB Weld on one side of some larger pieces so magnets stay in place on one piece. Hold piece and give it a bump to make sure it holds. Add more as needed. I use this on most all layered pieces so client can take apart for dusting, shipping , storage, etc. No complaints so far.
Nice work my daughter retired 2015 a chief.
I checked out the conversion to DXF and there are 2 lines for everything
Looks awesome I like the magnet idea, I have been welding on threaded studs, where do you get your magnets from?
Arclight 5x5 table
Delta 3 CandCNC controller
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Hypertherm PM 85
Linux computer
Solid edge 3D
SheetCam
Inkscape
Millermatic 211
www.ceeplasma.com
Amazon. Not that expensive considering the time it saves. I have not shopped around so likely can get better deal.bigworm36 wrote:Looks awesome I like the magnet idea, I have been welding on threaded studs, where do you get your magnets from?
Yeah someone else converted a flag I did and weird stuff happened. Maybe I should post it without the design edge cut paths.acourtjester wrote:Nice work my daughter retired 2015 a chief.
I would like that it may make a difference with the double lines
Tom
Tom
This is prior to converting to cut paths so it should show up as just single set of lines with no lead ins unless the software your using automatically converts it to a cut path.acourtjester wrote:I would like that it may make a difference with the double lines
Tom
Thanks but I use either DXF or SVG file formats maybe someone here can convert PCM to one of those
- Specialkfab
Looks like James converted it to DXF with the cut lines for a Plasmacam applied.acourtjester wrote:Nice work my daughter retired 2015 a chief.
DHC2 PlasmaCam 4X4
Pipe Attachment
HyperTherm 45XP
Pipe Attachment
HyperTherm 45XP
That is beautiful I am going to have to look into magnets great idea.
Very nice. Would like to make one for my Dad. What is the font used?
Don't recall and will need to look when I get home. I had to break apart fonts as needed to prevent fall outs. It as not a ready cut font.JesseB wrote:Very nice. Would like to make one for my Dad. What is the font used?
rickjamesbish wrote:Don't recall and will need to look when I get home. I had to break apart fonts as needed to prevent fall outs. It as not a ready cut font.JesseB wrote:Very nice. Would like to make one for my Dad. What is the font used?
Thanks, Showed it to my Dad he really likes it. He's looking forward to getting one.
Thank you for the file, your work is amazing!
Converted to DXF without double lines.
