Public Park Style BBQ Grill
- Peechy
Re: Public Park Style BBQ Grill
WOW love it!!
Great project, thanks..
down loaded fine thanks
Thanks for the post.
Is there anything particular you put on cooking surface, or do you just grind down and oil up ?
thanks for the share - looks great!
Thanks. I am going to use this as a class project I think and have them make these in pairs. What thickness of steel do you use? Is 10ga thick enough?
- otisa2007
i have built several using 10ga and havent had any problems
nice, thanks for sharing
- cguethert
what finish are you guys putting on these? just using steel grating?
First I want to thank you for the file. Second I cut all the parts and I'm trying to put it together and it doesn't all make total sense. The obvious parts make sense, sides,base,grill. But the smaller rounded piece and the one smaller rectangle piece are hard for me to figure. I saw the picture posted and it looks different. Anybody got a different picture,any help is appreciated.
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
What is your suggested metal ga for the grill?
thanks for sharing.
thanks for sharing.
love this great job
Is this dxf available anywhere?
look on the front page
Thank you!
Awesome! I made firepit from 3/16 steel and it warped a bit, would 1/4 be thick enough for this or go a bit more?
Thanks for the file!
