Sons Smokehouse
sfrsdavis
Sons Smokehouse
Post by sfrsdavis »
I have tried this in inkscape and there are too many lines to manually take out. Can someone help me out
rdj357
Re: Converting Help
Post by rdj357 »
Here you go, needs to be bridged and sized for your application but should get you started.
sonssmokehouse.dxf
sfrsdavis
Re: Converting Help
Post by sfrsdavis »
Man I can't thank you enough!! Thank you!!
rdj357
Re: Converting Help
Post by rdj357 »
No problem! Maybe a little help for future work. When tracing an image with reflections and other undesirable details it is a good idea to edit the raster image first. I use a free program called paint.net that you can google search for and download. It works great for me and I don't have to buy photoshop!
I use the magic wand selection tool and adjust the tolerance to select items and either erase or paint inside that selection. For instance, those letters have a textured look that will play hell with a trace so I select them with fairly high tolerance which will pick up to the outline of the letters and then painted them black. After you have that, you can choose to invert the selection and erase - it won't erase in areas not selected so it will leave nice crisp edges for your vector trace to pick up! Good luck!
Jhva
Re: Converting Help
Post by Jhva »
Thanks for the info on tracing rdj357!
Probotix Meteor CNC Router
Vectric VCarve Pro Software
DXF
Re: Converting Help
Post by DXF »
rdj357 wrote:No problem! Maybe a little help for future work. When tracing an image with reflections and other undesirable details it is a good idea to edit the raster image first. I use a free program called paint.net that you can google search for and download. It works great for me and I don't have to buy photoshop!
That turned out nice! I use Adobe Photoshop and do basically the same thing. I usually convert the pic into a grayscale, then adjust the contrast - then use the magic wand or eraser to get rid of things I don't want and use a gaussian blur of (.6). The Gaussian blur smooths the edges and then save as a PNG. Inkscape usually traces it nicely. Nothing comes out perfectly but it gives you something to work with.
Dave
kchoghead
Re: Converting Help
Post by kchoghead »
Tried google for paint.net.....no suggestions...do you have a direct website?
rdj357
Re: Converting Help
Post by rdj357 »
I googled "paint.net download" and the top 8 results were all good download sites. Here's the main one I think:
https://www.getpaint.net/download.html
kchoghead
Re: Converting Help
Post by kchoghead »
rdj357
Re: Converting Help
Post by rdj357 »
acourtjester wrote:Hi
I tried to follow the steps below that you posted and could not paint the letters after I high lighted them.
I have the basic Paint 4.0.16 version are you using any add on to the basic?
I mainly use Inkscape but have used Paint for some work around to clean up images to remove some elements.
I thought I'd post this here in case it helps anyone else. Here's a short video of using Paint.Net to clean up an image for tracing. Hopefully it helps more than me trying to bumble around typing it out. Of course you have to tolerate my blabbing about what I'm doing but anyway maybe it will help a little!
https://youtu.be/xEzVGRxDw88
Re: Converting Help
Video really helps, Downloaded it to play when I want to learn more about how to do things in Paint. Give another tool when tracing clip art.
Thanks rdj357
