pricing?
jwallmuth
pricing?
Post by jwallmuth »
how much should I have charged for this job? I had to draw both, and there were 4 each, total of 8 sheetS, and they are 48" WIDE
motoguy
Re: pricing?
Post by motoguy »
One beeeeellion dollars.
Seriously though, you give us basically no information to go on. What's your metal cost? Did you have to draw the design, and if so, how long did that take? What's the square inches of material used? Inches of cut? Number of pierces? I would need those for a start.
little blue choo
Re: pricing?
Post by little blue choo »
Like motoguy said. The more info you give the more responses you will get. With the supplied info it looks like you used 2 full 4x8 sheets of steel, what kind or gauge I don't know. It looks like you may be cutting stainless or alum. but I don't know. I would have to say depending on the material used, somewhere between $300 and $500. Looking forward to your response.
Rick
Rick
Arclight 9600 4x8 table
jwallmuth
Re: pricing?
Post by jwallmuth »
ok, I'm sorry, this is my first job for my plasma table. customer supplied material, and I had to vectorize and fix the images to be able to cut, it took me a long time draw, but I'm still learning. how do I find out how many inches and how many pierces? thanks again for all the help
Re: pricing?
Post by tnbndr »
Again, we need more information!!! What software are you using? for CAD for G-Code?
See post above with information in the signature, you can add yours to your signature for future reference.
Re: pricing?
If you do a job report in sheetcam it shows how many pierces and inches in it.
jwallmuth
Re: pricing?
Post by jwallmuth »
ok ill go and look this up right now, I have a bobcad/bobart, sheetcam, and mach3, thanks for all the help with this again guys
motoguy
Re: pricing?
Post by motoguy »
Here is where the job report is located:
jwallmuth
Re: pricing?
Post by jwallmuth »
this should be what y'all r looking for, please tell me how to figure out pricing from here, there was 4 of each, for a total of 8 thanks a lot again for the help
little blue choo
Re: pricing?
I get .15 per Pierce and .10 per cut inch plus $60 per hour design time and usually charge a 1 hour min. unless it is very simple and I can do in a minute or two then sometimes ,depending on the customer I will only charge a have hour $30. That would be per design not per sheet cut.
WHAT DID YOU CHARGE THEM ?
Rick
Rick
jwallmuth
Re: pricing?
Post by jwallmuth »
little blue choo wrote:I get .15 per Pierce and .10 per cut inch plus $60 per hour design time and usually charge a 1 hour min. unless it is very simple and I can do in a minute or two then sometimes ,depending on the customer I will only charge a have hour $30. That would be per design not per sheet cut.
Rick
using the numbers you gave me, it came to $286 for pierce and inches, plus design fees
then I hit it on the head just shooting from the hip then. cause I charged him $300 for the cutting, $25 per drawing, and charged him a $50 art few cause the lady that does his art work for his logo WOULD NOT give me the vector file, just a eps file so I had to fix the art work just to use it. does anybody charge a consumable fee?
kb3gun
Re: pricing?
Post by kb3gun »
Pierce charges (0.15 per) usually cover my plasma consumables. Flap discs or any after cut processes are billed accordingly.
-Smitty
Torchmate 4X4 Growth Series w/AVHC
Hypertherm PM45 w/ Machine Torch
Miller Syncrowave 210 TIG
jwallmuth
Re: pricing?
Post by jwallmuth »
Thank you, what's the goin charge per inch?
