TATTERED AMERICAN FLAG
Does anyone happen to have the tattered American flag file in DXF format they wouldn't mind sharing ? Got a hometown hero I want to make one of these for please.
Thank You
Thank You
Re: TATTERED AMERICAN FLAG
Thanks for the file!
Thank you for the file.
Thanks for the file.
LOVE IT!!!!! Thank you!!
anyone have a tattered rebel flag?
PlasmaRoute "DO NOT BUY there Plasma table from this company NO Support"
Thermal Dynamics A-60
ArtCam
Sheet Cam
Mach3
Refrigerator dry Air
Charlotte,NC
https://www.facebook.com/pages/ACSD-Art ... 90?fref=ts
ArtCam
Sheet Cam
Mach3
Charlotte,NC
- d2day
Thank you for the file.. I have a veteran in mind for this also. I appreciate your time and efforts in making and sharing the file.
Mach 3
SheetCam
Corel x5 / Version 12/ Version 7
ArtCam 7.0
CNC Router
ULS Laser
4x4 Plasma Table/Hand Built
HyperTherm PowerMax 45
Cut Shop Software
LCTHC
SheetCam
ArtCam 7.0
CNC Router
ULS Laser
Cut Shop Software
LCTHC
Thank you for the file! Good work!
hey thanks man, any way i could get this in an svg?
Download Inkscape (free) you can open both DXF and SVG files formats then change them to the other when needed. Download the original file from here then convert it with Inkscape and save it in SVG.
Thanks, claddagh.
I cut two right after your post. One went to a Army reunion as a door prize ( have not heard back yet). The other one went to the Blueberry Festival, and I had people almost fighting over it ( Ha! ). I wish that I cut a half dozen for the weekend . I did get a order for 3 and maybe a order to go to Texas. I did mod to the Stars ( not drop out ) and hung a Heart and Mich. to the bottom, torch heat the blue area and Bill's red dye.
Thanks Again,
Dale..........
Thanks Again,
Dale..........
I tried opening it up in inkscape and it didnt work corectlyacourtjester wrote:Download Inkscape (free) you can open both DXF and SVG files formats then change them to the other when needed. Download the original file from here then convert it with Inkscape and save it in SVG.
- Larry83301
ranger#1 wrote:I tried opening it up in inkscape and it didnt work corectlyacourtjester wrote:Download Inkscape (free) you can open both DXF and SVG files formats then change them to the other when needed. Download the original file from here then convert it with Inkscape and save it in SVG.
See if this will open for you.
so,i got it to open in solid edge, re saved it as a .dxf then it would open in inkscape, then it would open in sheet cam, weird.
i wana do a big one like 5x10.
Thank you I have been looking for this file or trying to recreate! I love this forum! I will be posting some of my designs!
- csplazma1
I was able to cut of course you will need to clean it up or it will not cut properly. I just cut an 18x32 and it turned out pretty good. will adjust measurements as to not waste too much metal. We have never used patina colors and will be giving that a shot. For the new folks always check and double check your cut paths!! Tried Steel FX for the first time and highly recommend an air brush with the metal dyes. Used a cotton ball on this one and is ok. Here are the files.
C&S PlaZma Metal Works
LDR Motion Systems 4X8 Water Bladder
Hypertherm Powermax 85 Machine Torch
Everlast PowerPlasma 60 Handheld Torch
Thunder Laser NOVA 51
Thank you for sharing. Very nice! JayG
PlasmaCam DHC2
Miller EconoTig
Miller MIG
Lincoln MIG
Millwright Knee mill (older than me!)
LeBond Lathe (older than me!)
Miller EconoTig
Miller MIG
Lincoln MIG
Incredible talent..... Thank You!!
- Serenityfab
Wow! There are some amazing artists on the Forum.
Thank you to everyone who help others to do better...
Serenity Metalworks
Bozeman, Montana
Plasmacam with homemade vent hood and Penn State dust collector
Hypertherm torch
It's not the size of your shop but what you do with the tools inside!
Bozeman, Montana
Hypertherm torch
i can open this in bobcad, but it won't open in sheetcam it just keeps saying a problem has caused the program to stop working correctly, any suggestionsLarry83301 wrote:ranger#1 wrote:I tried opening it up in inkscape and it didnt work corectlyacourtjester wrote:Download Inkscape (free) you can open both DXF and SVG files formats then change them to the other when needed. Download the original file from here then convert it with Inkscape and save it in SVG.
csplazma1 wrote:I was able to cut of course you will need to clean it up or it will not cut properly. I just cut an 18x32 and it turned out pretty good. will adjust measurements as to not waste too much metal. We have never used patina colors and will be giving that a shot. For the new folks always check and double check your cut paths!!Tried Steel FX for the first time and highly recommend an air brush with the metal dyes. Used a cotton ball on this one and is ok.
how did you like steel FX stuff?
- csplazma1
Took a little to get used to and when they say airbrush is the best application they mean it. Only one issue I had was that my blue for what ever reason keeps coming out more aqua colored than blue. I am not getting the brilliant cobalt blue that I thought I would or as pictured in most of the pictures others post.
