help ...very urgent
hardsteel
help ...very urgent
Post by hardsteel »
hi guys .
i have cut hundreds of plates since a got my plasmacam,
today when i complete cutting large plate using indexing , i found that the size not as the picture i need , the machine cut some paths in picture so they are shifted their position (the machine cut a bout 1 in down of the real position ) , i do not know software fault? , recoder fault ? , i have reinstalled the software more time, but the same issue ......any help will be appreciated.
Dan-PlasmaCAM
Re: help ...very urgent
Post by Dan-PlasmaCAM »
From the Description I can't really tell what is going on. Our Techs are on this site.
http://www.plasmacam.com/ownerdash.php
Post by BrianMick »
Check for slippage on your belts and gears......You can find a whole section on this in the video manual....I had this happen to me and that is what the problem was. I replaced my gears and belt and all was fine in the world.
james.davis
Post by james.davis »
I have had thar same problem and shut down my system and let it reboot it worked fine for me .
Jim
