this is the way I see 'em- use Corel Photopaint, Corel Trace, Corel Draw- edit nodes, clean lines and export to layered DXF; import to Flashcut CNC
this attached file will need to have elements ungrouped, placed in respective layers, and remember the outer element must be the highest numbered layer or top layer in the object manager dialog box (Corel). In Corel, you can't open and edit layers in the DXF- only the CDR file- I always save two files, the CDR and the DXF
the way I see 'em
the way I see 'em
Re: the way I see 'em
and another...
and another..
- JJsCustomDesigns
or you can download file. Open in sheetcam. create your tooling paths and post to mach.enfofan wrote:this is the way I see 'em- use Corel Photopaint, Corel Trace, Corel Draw- edit nodes, clean lines and export to layered DXF; import to Flashcut CNC
PM me with details
PM me with details
and a generic front end
artistic license?
I open and edit DXF files all the time in Corel. Just open the file and select ungroup all and you can remove all the top layers then hit combine and save .
- Gamelord
- 4.5 Star Member
Same here, in coreldraw, just use the ctrl+ pgup or pgdn to move an object to the front or back.
Also....thanks for sharing.
Torchmate CAD
Torchmate CAD
