Here is a Plasma SHAPE generator wizard for the Mach3 users. Unzip it into the addons directory. Then select it from the wizards tab in Mach3.
It allows you to generate Gcode files for basics shapes like square, rectangle, triangle cirlce,oval,hole, straight lines and angled lines.
Basically a conversational program to do basic shapes.
(;-) TP
Plasma Shape Wizard for Mach3 users
- Attachments
- Plasma Shapes Wizard.zip
- (35.48 KiB) Downloaded 374 times
Re: Plasma Shape Wizard for Mach3 users
Thanks for that vmax, I'll give it a try
Murray
Murray
Here is an updated version to use. I forgot that there are several different version of the TOM that mach users USE. Now you have the option of G28.1, G31, or NONE. AND you can set the switch offset for your setup. Just like the big boys.
(;-) TP
(;-) TP
- Attachments
- Plasma Shapes Wizard2.zip
- (27.2 KiB) Downloaded 364 times
