oblong shape
vickiegib1
oblong shape
Post by vickiegib1 »
i know how to make a oval and round shape but how do you make a oblong shape like a race track ? what do i do to get this
I Lean
Re: oblong shape
Post by I Lean »
I start with two circles, connect them with straight lines, then delete the remaining half-circles.
PalmetalDesigns
Re: oblong shape
Post by PalmetalDesigns »
I know an old topic but I would draw a rectangle and then fillet the corners.
planetxfred
Re: oblong shape
Post by planetxfred »
Like many tasks, there are many ways to accomplish this. Another way is to draw a circle, using the stretch points function (under edit in 3.11) capture half of the circle and drag it the specified distance. Use the orthoganal setting to keep it square, (obviously works only in horizontal or vertical. This method does have limitations but is quick and easy.
Fred
