Simple chart to help with STEEL cut settings not listed in the PrimeWeld manual. These may not be the optimal settings for you, but will be a great place to start to further dial in to perfection. .PDF file attached
PrimeWeld Cut60 Settings Chart
Re: PrimeWeld Cut60 Settings Chart
Great looking chart, I will give it a try and see if i have better luck, I was cutting everything at WOT.
DIY 4x8 table
Powermax 65
Powermax 65
A good visual always helped me so i figure i cant be the only one, thanks. The values are (for the most part) interpolated from the settings chart primeweld provides in their manual. Likely wont be perfect but otta be in the ball park.kicktillmonday wrote: ↑Mon Feb 05, 2024 12:17 pm Great looking chart, I will give it a try and see if i have better luck, I was cutting everything at WOT.
