I can not seem to figure out how to fix the file with my tractor sign. It appears to me that the silhouette of the tractor will be the only thing that will be cut out, and not the details of the tractor. If someone can help me with this I would greatly appreciate. Attached is the file which you are welcome to use.
Need help with tractor
Re: Need help with tractor
Are you able to post the design in dxf?
Had a look in Corel at your design and it appeared to open up just fine, see image below. I re-saved it as a DXF from Corel for you to see if that opens up better for you.
Thank you so much I really appreciate the help.
Your welcome, just curious if the file I uploaded worked properly for you?
hselcer wrote: ↑Wed Dec 06, 2023 1:29 pm I can not seem to figure out how to fix the file with my tractor sign. It appears to me that the silhouette of the tractor will be the only thing that will be cut out, and not the details of the tractor. If someone can help me with this I would greatly appreciate. Attached is the file which you are welcome to use.
TRACTOR SIGN.pcm
- Joe Jones
Nice, clean solution, David! You also cleaned up the islands. Good work!
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
This is awesome! Thank you so much for the help!
