Mounting Tabs
Mounting Tabs
I am working on a 3' sign to hang and stand off 1". I am neeing a way to mount the sign where the standoff cannot be seen. Any ideas? I have a couple of weld on ideas. My current plan is to create a bracket the will weld on a 1" stand off with a tab that sticks up for the wall anchor. This is my first one like this. Any suggestion is appreciated.
- ROKCRLER
Re: Mounting Tabs
Here are some ideas viewtopic.php?f=89&t=33745&p=217190&hil ... ng#p217190
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
- tnbndr
Re: Mounting Tabs
So I do a modified French Cleat.
In your case I would weld I would weld a 1" angle iron on the back of the sign near the top with the leg facing down. Then I weld up an offset cleat that gets fastened to the wall and accepts the down leg of the angle iron on the sign. At other positions on the sign I just weld on 1" spacers or short pieces of the same angle iron so that the sign hangs flat.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
