Updated the Hub Utility firmware from 1.6 to 1.8. Also updated the firmware for DTCH 5. Now the torch will not fire.
Is there more to the process when updating the Hub Utility?
Linux Mini Computer Command CNC 1.2.2
Bladerunner
Bulltear StarLab 5' x 10'
Hypertherm Powermax 85
Updated Hub Utility firmware and now the torch will not fire
Re: Updated Hub Utility firmware and now the torch will not fire
First thing is to look at the pwm for a red light to come on. If it does not then press reset or cycle power on the hub. Also use the number on the gantry if you need more assistance.
