looking for bbq pit end with clean out
looking for bbq pit ends with clean out and smoke control please help
Re: looking for bbq pit end with clean out
Maybe show us some pictures of some you have seen (google search) so we can get a better idea of what you want. Are you looking for the complete design, or only for the "ends with clean out" and "smoke control"?
yes just the ends and smoke control
similar to these but with the whole cap so i can cut, and tack it up then finish cutting the door out. very new to this any help is appreciated thanks!
- tinspark
This is the firebox vent. Which controls combustion air in the firebox. The air inlet works best at the fire grate height or just below it. That way air draws up through the fire and supplies proper oxygen in order to support combustion. The one depicted shows it above the grate and is not located at the optimal position above the fire grate/ A lot of pitmasters prefer the slide air inlets. They also can be located on teh side of the firebox.Squatchemup wrote: ↑Tue Sep 21, 2021 10:42 pm similar to these but with the whole cap so i can cut, and tack it up then finish cutting the door out. very new to this any help is appreciated thanks!
Sites like https://www.smokerbuilder.com/ have a free smoker calculator (below) another is Feldons smoker calculator. http://www.feldoncentral.com/bbqcalculator.html It shows you how to calculate the entire pit so that it purrs like a kitten and will produce the "thin blue smoke" that everybody raves about..
Edit: http://bbqpitcalculator.com/
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
Here is one I just drew up for you. You could scale the size to meet your specific needs.
- Cz_apie
Nice file Adbuch
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
Hypertherm PM 65
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
Rong Fu 25 Mill
Thanks! Glad you like it. Happy to help.
thank you sir
You are welcome! Let us see what it looks like when you get it cut and finished.
- otisa2007
See if this file helps it's a door I've used on some smokers
found this on Langmuir website cut great
