After updating to this version (attached), when I import svg file the 1:1 scale does not work. I had to change it to 1:1.079 to get the correct dimension?
Thank You
Kenny Baker
Scaling on import svg
- Attachments
- Version
- Sheetcam.PNG (8.42 KiB) Viewed 295 times
Re: Scaling on import svg
The SVG standard scaling has changed from 90 DPI to 96DPI. I changed SheetCam to comply with the newer standard but this breaks drawings fom older cad packages. I'll add a 90/96DPI option in the import drawing options.
