garden gnomes
- sparkey
garden gnomes
a few of the gnomes i made from pictures
Glenn Sparkey Wilson
owner SD Custom Machining & Signs
5 x 5 Maverick CNC Table
85 Hyperthrem
85 Hyperthrem
- sparkey
Re: garden gnomes
85 Hyperthrem
85 Hyperthrem
- rdj357
Re: garden gnomes
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Re: garden gnomes
thanks for the great share
- sparkey
Re: garden gnomes
i cut them yesterday they cut great but drops sometime dont drop and one hit the torch
85 Hyperthrem
85 Hyperthrem
Re: garden gnomes
WOW! Thank you
Re: garden gnomes
These are great! I downloaded the dxf file, however all i got were a bunch of lines. Can anyone help me sort out why?
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
- Larry83301
Re: garden gnomes
Must be your CAD program isn't talking with what he posted, try again and if it still doesn't work let me know and I post it as an ACAD R14, that seems to work for most people.
- cstroke
Re: garden gnomes
nice ones, you'd think these should sell.
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
Re: garden gnomes
I tried a couple more times with no luck. If you don't mind, i sure will appreciate it!
Larry83301 wrote: ↑Mon Mar 08, 2021 2:32 pmMust be your CAD program isn't talking with what he posted, try again and if it still doesn't work let me know and I post it as an ACAD R14, that seems to work for most people.
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
Re: garden gnomes
Cut a few of these and they are fantastic. I did go in and change the dimensions a little making the spaces a bit smaller and strengthening the outline. It seems to work better with my machine. Looking forward to finishing them. I will weld some stakes on many of them, I think they will look very nice in the garden. Not sure on the colors I will use. I feel they will sell very well.
Thank you for the file!!!
- sparkey
Re: garden gnomes
i have made 5 more designs i take pic and modify them i cut about 40 of them people like them and weld 1/4 rod so they stick in the ground
85 Hyperthrem
85 Hyperthrem
- sparkey
Re: garden gnomes
85 Hyperthrem
85 Hyperthrem
- Larry83301
Re: garden gnomes
Re: garden gnomes
Thanks, really like the tree branch one
- sparkey
Re: garden gnomes
thanks
85 Hyperthrem
85 Hyperthrem
Re: garden gnomes
It worked! Thank you!!
Larry83301 wrote: ↑Fri Mar 12, 2021 10:26 amdwmetal wrote: ↑Thu Mar 11, 2021 7:36 pm I tried a couple more times with no luck. If you don't mind, i sure will appreciate it!
GARDENGNOME -A.rar
Here you go. I saved it as an ACAD R14, let me know if it works for you, OK.
My file was to big to post so I made a RAR file, just un-rar and you get the DXF file.
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
Tracker CNC 4x8
Hypertherm
Corel Draw
Ontario, Canada
- Peechy
Re: garden gnomes
Great share ! Thank you !
Re: garden gnomes
Thank you very much for the file
- sparkey
Re: garden gnomes
Your Welcome
85 Hyperthrem
85 Hyperthrem
- Larry83301
Re: garden gnomes
Here is the file as an SVG. It is still to big to post unless it's a RAR file so try thisLarry83301 wrote: ↑Fri Mar 12, 2021 10:26 am I tried a couple more times with no luck. If you don't mind, i sure will appreciate it!
GARDENGNOME -A.rar
Inside is the SVG
Re: garden gnomes
Thanks for the files guys! Wife is going to love these!
Re: garden gnomes
I downloaded the zip file but gnomes 14 and 15 don’t seem to be there. Does anyone have these files? I tried creating them from the picture but without much luck.
- Larry83301
Re: garden gnomes
sparkey could you post the file with the numbered pieces, it's just a little different than the file you posted. The one you posted is the same as the file in this picture, in the other picture are a couple of different GNOMES, they are all standing up and have posts on the backside and are numbered.
Thanks in advance,
