Easyscriber without THC?
I’m using the Langmuir Crossfire XL without THC. Will this work? I should have asked before it arrived
Re: Easyscriber without THC?
The easyscriber doesn't use THC. THC uses voltage feedback from the plasma cutter to maintain the correct arc gap. There is no voltage feedback from the easy scriber. You just manually set the pressure on the scriber.
