What divider card ratio do you run on your system
SegoMan DeSigns
Post by SegoMan DeSigns »
Tom,
I just bought a Hypertherm 105 that was tied into a 2 yo Bullteer system that has your controller on it, what ratio do you use off the Hyperthem system for the THC. I forgot to check the dip switches before I mounted it..OOPS
Thanks in advance,
weldguy
Re: What divider card ratio do you run on your system
Post by weldguy »
Could be 7:1or 50:1 depending on exactly what C&CNC module it was mated to. I would double check the divider card.
SegoMan DeSigns
Thanks for the reply, I thought about doing a cut and measuring the voltage at the THC with it turned off but I better play it safe and do a visual.
Edit:
I just did the visual it was on 50:1 the 7:1 you mentioned is not an option on settings for the 105.
Return to “CandCNC Forum”
