My program ran great for years. Now new G code files new and existing files want to start at almost 600
Inches per minute, it also
Says 3%. Not sure how to correct this. Each cut just as it starts I have to hit resset then it will
Be at the required 220 Ipm
Cut speed defaults to fast
Re: Cut speed defaults to fast
mach3 / mach4, 3% of what?
can you post an example gcode file please
can you open your profile (the XML file) with a text editor like notepad or notepad ++, copy all (ctrl +A)
create a code block in your forum reply (<\>) in the full editor and paste the XML file contents within the code block (ctrl +V). and I'll take a look at it or someone else will
you've not provided enough info and my crystal ball is not working today
