Circle problems
beefy
4.5 Star Member
4.5 Star Member
Re: Circle problems
Post by beefy »
Leeroy6392 wrote: Thu Aug 22, 2019 8:10 pm The tap file I use to load into Mach 3 would not upload so I’m back out in my shop trying some different stuff.
On which Mach3 version where would I find that?
Doesn't matter then. If you can't upload any files then can't help. Was going to load a copy of your profile on the same version of Mach and test with your file, but guess that's not possible now, seeing as you won't be able to upload your profile too.
Good luck with the troubleshooting.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
lockeyone
Re: Circle problems
Post by lockeyone »
Change your file.tap to file.old or .txt or something like that and see if you can upload it. Just explain you did that so the person helping can change it back to tap file. Just a thought.
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
ctgolfer1
Re: Circle problems
Post by ctgolfer1 »
Interesting thread, Good Luck Leeroy!
I have nothing to add.
Nice to see all the good folks trying to help.
Staying tuned for the outcome.
Re: Circle problems
There is a great way to transfer files of any size by using the Google drive, it is free for up to 15 Gigs of storage. You upload what you want and then send a link to a persons email address and they can download from the Google drive. Only drawback is you cannot use a Yahoo email they don't play nice with Google. I have used this to send videos and doc to anywhere. :Yay here are the instruction for downloading a folder of file or video.
Google drive download.doc
(171.5 KiB) Downloaded 48 times
Leeroy6392
Re: Circle problems
Post by Leeroy6392 »
thanks for the help again and acourtjester I would never have figured that out on how to convert it.
water leg 8-22-19.DXF
(4.01 KiB) Downloaded 40 times
Leeroy6392
Re: Circle problems
sbest1
Re: Circle problems
Post by sbest1 »
Our machine was doing this. We bought new pinions and timing belts and re-calibrated the axis for x and y. Solved the problem.
Return to “Mach3 & Mach4 CNC”
