Belt Sander
Maadman
Belt Sander
Post by Maadman » Sat Sep 15, 2018 3:56 pm
I've heard you can use a wood belt sander to remove dross from metal. Anyone ever try it? Would love some info, so tired of flap disks!
Re: Belt Sander
Post by acourtjester » Sat Sep 15, 2018 5:28 pm
Have you tried to use Muriatic acid and water 50/50 couple of hour dross gone. :lol:
You do not have access to view or download this file.
Become a Contributing Member to gain access to this feature. Click Here
Everlast PM 256 tig
Maadman
Re: Belt Sander
Post by Maadman » Sun Sep 16, 2018 11:04 am
Thanks for the suggestion. I sure have tried it I know it works very well for many people. It was good, but not that good. I also have a metal building, it doesn't like Muriatic acid at all! I do a lot of smaller text with tight curves that produces a lot of dross. It's what I like to do, and it sells well, so I am probably always destined to have a lot of dross. I know I have heard of people successfully using wood sanders for metal. Want to give it a try, and if anyone has any tips I would love to hear them.
CleanCutCreations
Re: Belt Sander
Post by CleanCutCreations » Thu Aug 29, 2019 3:51 pm
I was thinking about trying that also. Did you ever try it?
Re: Belt Sander
Post by acourtjester » Thu Aug 29, 2019 8:11 pm
Have you tried to knock the dross off with a small hammer, if you strike it at an angle it will break off most of the large dross. Just work around the part with the hammer. I then use a flap wheel to clean the rest off, but the acid dip is the easiest to do.
Everlast PM 256 tig
Maadman
Re: Belt Sander
Post by Maadman » Fri Aug 30, 2019 10:01 am
I've tried the hammer thing, not so hot on 14 gauge. I did try a wood sander, but it did not have a sensor to keep the sanding belt in position. That is not good! If we can keep the belt on track it works well.
Easyscriber engrave attachment for Hypertherm plasma cutters.
