Snoopy & The Great Pumpkin
Would someone mind taking a look at this drawing and see if you see any obvious mistakes before I attempt to cut please? This is my first trace and I'm not really sure how some of these cuts will play out. For example, the lines on the leaves on each side of the pumpkin... will the torch just make a pass and cut the line the width of the kerf or will it ignore a line that is just standing alone like that?
I do think that I need to go back and adjust those cuts inside of the pumpkin. The ones that run vertical on each side. They seem to measure almost a 1/2 inch wide and I think they should be about 1/4 inch wide.
Anyway, this was my first trace and I'm not very confident in it so I hate to waste a 2 foot piece of metal if there are obvious mistakes.
Thank you in advance for any feedback or advice.
LDR 4'x4' Water Table
Command CNC Linux Controller
Plate Marker
Power Max 45xp w/ Machine Torch & Hand Torch
2 Stage filter, Motorguard filter & HF Ref Dryer
InkScape / SheetCam
Plate Marker
InkScape / SheetCam
- rdj357
Re: Check dxf please...
Looks good to me - not sure how your software will handle it but there were a few paths that didn't quite make it to join up and a couple places where there were some extra nodes but overall it would probably cut just fine.
Here it is after I did the little minor cleanup in case you want to compare.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
Re: Snoopy & The Great Pumpkin
thanks for the share..looks great
looks good I will try it
Thanks.
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Thank you everybody loved it....
Chip
Chip
Love it thanks for sharing
This is great, going to cut one for Halloween. Thanks for the share!
- gslavik
Nice work, Thank you for sharing!
