Sequential numbering for placards
rbmgf7
Post by rbmgf7 » Wed May 23, 2018 11:15 am
Wondering if anyone has a tip on how to generate sequential numbers. I had someone ask if I could cut door numbers, from one to two hundred, with the possibility of having the company logo on the placard.
I know the hard way to do it but was wondering if anyone has an easier solution.
I used CorelDraw8 and Fusion360.
SegoMan DeSigns
Re: Sequential numbering for placards
Post by SegoMan DeSigns » Wed May 23, 2018 12:08 pm
I don't think 8 has a merge file option.
If it does you make a template with the logo on it then then link it to a database, in this case an Excel spreadsheet. In Excel you start a numbering sequence and finish it with a copy & special paste command. Hit merge and the magic happens. Sounds Simple Right?
tcaudle
Post by tcaudle » Thu May 24, 2018 9:40 am
There may be a sequential numbering plugin for CorelDraw. Have a look at this one says it does automatic numbering and uses a database
http://macromonster.com/product/alexand ... lestool-2/
lockeyone
Post by lockeyone » Thu May 24, 2018 9:58 am
You also try searching the internet for "Print Merge"
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
islander261
Post by islander261 » Thu May 24, 2018 10:20 am
It will require some hand editing of a base file but there are plenty of Gcode subroutines floating around for generating sequential numbering.
John
