Hey Peter, I am not sure how to tell, it may still be considered a Duramax torch I don't know. I was told that if your torch uses the consumable parts listed below this will work with your torch.mayper wrote:Hi Everybody,
I have a machine torch on my powermax 45, my question is how do I tell if its a Duramax torch.
Peter
EASYSCRIBER QUESTIONS
Re: EASYSCRIBER QUESTIONS
Will the easyscriber work with a Powermax 900, Pac hand torch? I know, old school, but it works, plus I got a good deal on it.
Thanks for any information you can provide.
Robert Johnson
Robert Johnson
From what I know it is only available for newer Hypertherm models.RobertJohnson wrote:Will the easyscriber work with a Powermax 900, Pac hand torch? I know, old school, but it works, plus I got a good deal on it.
Robert Johnson
I have a HP with a T80 torch. Will it work?
Thanks, just wondered, was hoping it would work with the pac 123, hand torch. Think that's what I have
- Sampson Jones
Anybody want to tell me how to set this up in sheetcam ?
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
CandCNC electronics
Command Lineux
Super z 2
Re: EASYSCRIBER
I am not a Sheetcam user but above is what motoguy suggested near the beginning of this thread.motoguy wrote:When I want to draw with my ink pen, etc I just use the "Mach3" post, which is a router post.
- Sampson Jones
Here my torch Hypertherm t45m iec60974-7 Im assuming the easy scribe will not work with this powermax torch ? Is that correct ?
- Attachments
- IMG_1578 (1).jpg (75.52 KiB) Viewed 3389 times
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
No it won't, I looked into this myself before before buying mine. Look at weldguy's post at the top of this page and your torch must use those consumables for this to fit. Those consumables are found on the 65, 85, 105, and 45xp.Sampson Jones wrote:Here my torch Hypertherm t45m iec60974-7 Im assuming the easy scribe will not work with this powermax torch ? Is that correct ?
- Sampson Jones
CandCNC electronics
Command Lineux
Super z 2
CandCNC electronics
Command Lineux
Super z 2
With a little mod it works with T80 hand tourch
I have a powermax 85. I just received my easyscriber and question is do I turn on my pm? and they said I do not have to mess with my settings . I use shopsaber and pronest . Can someone help me ?
I don't have one, but I wouldn't think you would want your plasma cutter on since the scriber replaces the consumables. This might cause problems with the arc ok setting not showing up and not allowing the table to move.
- EasyScriber
We just signed up for the forum to assist with questions like this. I see your post is a few weeks old so you likely have it figured out by now.
Your plasma cutter will not operate with the EasyScriber installed however we still suggest turning the plasma cutter off when scribing.
Machine settings for scribing vary depending on what plasma cutting table and/or what software you are using.
If you still have any questions please let us know and we will be happy to help.
Easyscriber, as you've jointed the forum.
What's the chances of a Powermax 45 (non-XP) scribe being issued?
besides market size.... what could we do to help expand your product portfolio? (happy to provide some dims for the barrel etc).
I'm sure other plasma torch users would be happy to do other similar such measurements for the development of a few prototypes (I think the S60 and S45 are fairly common torches that have been copied and cloned by a few now
https://trafimet.com/catalogues/Trafime ... orches.pdf
- EasyScriber
We have had a lot of interest in a unit for the Pmax 45 and we wanted to offer one. We recently found that the physical size of the consumable set in the 45 torch is too small and there is just not enough room to make it work. Thanks for the link to the replacement torches that could be very helpful!robertspark wrote: ↑Fri Dec 14, 2018 9:46 am Easyscriber, as you've jointed the forum.
Thanks very much, I now understand the reason why the pmx45 is not offered,much appreciated.
I have a plasmacam table and a hypertherm Hypermax 85. I am thinking about purchasing the Easyscriber. Can anyone assist me in setting up my plasmacam so it will go through the motions of scribing and not give error message for not making contact with the metal? It looks like I can completely leave the cutter turned off while scribing.
I have watched the video, and setup looks very easy. Just mot sure about setting in plasmacam software. Any help will be greatly appreciated. Thanks
Boyd Fortin
Boyd Fortin
- EasyScriber
Check out this topic viewtopic.php?f=172&t=28846 and post any questionsbafortin wrote: ↑Tue Feb 26, 2019 2:05 pm I have a plasmacam table and a hypertherm Hypermax 85. I am thinking about purchasing the Easyscriber. Can anyone assist me in setting up my plasmacam so it will go through the motions of scribing and not give error message for not making contact with the metal? It looks like I can completely leave the cutter turned off while scribing.
Boyd Fortin
I have got everything I need. It works great.
- EasyScriber
Good to hear, thanks for getting back!
Would love to see some of the things your doing with your PlasmaCam & EasyScribe if you get the chance to post pics
Will my PMax 1000 work with this tool? Looks like it would be fun to have!
Thanks in advance.
Thanks in advance.
PlasmaCam DHC2
Powermax 45XP
Tig
Mig
A hammer
Powermax 45XP
Tig
Mig
A hammer
- EasyScriber
Unless you have the newer style torch that uses the 220842 electrode it will not.
Let us know if you have any additional questions and we will be happy to help.
OK, this has the 220842. Great, will get my order in!EasyScriber wrote: ↑Thu Oct 17, 2019 9:25 amUnless you have the newer style torch that uses the 220842 electrode it will not.
PlasmaCam DHC2
Powermax 45XP
Tig
Mig
A hammer
Powermax 45XP
Tig
Mig
A hammer
BTW, this will be used on a PlasmaCam DHC2, with the 3.11 software. Anything in particular to be aware of?Dragfluid wrote: ↑Sun Oct 20, 2019 3:31 pmOK, this has the 220842. Great, will get my order in!EasyScriber wrote: ↑Thu Oct 17, 2019 9:25 amUnless you have the newer style torch that uses the 220842 electrode it will not.
PlasmaCam DHC2
Powermax 45XP
Tig
Mig
A hammer
Powermax 45XP
Tig
Mig
A hammer
