3D models
Post Autodesk AutoCAD related questions and tips in this topic.
Welding1993
3D models
Post by Welding1993 » Wed Dec 20, 2017 9:42 am
Hello, I am running Solidworks and I was trying to figure out a way to take a 3D model and make it to where I can cut it on the table then assemble it. Anyone have any tips?
MemFor
Re: 3D models
Post by MemFor » Wed Dec 20, 2017 1:22 pm
It's more of a low tech way to do it but free, using pepakura designer: http://www.tamasoft.co.jp/pepakura-en/
I typically use it for paper craft models but can be used for metal also. It will "unfold" 3d model then you can just convert it into your drawing program.
BanksAg
Re: 3D models
Post by BanksAg » Wed Dec 20, 2017 11:33 pm
I don't know Solidworks, but I use Rhino which I'm told is in many ways comparable. In Rhino there is a Make2D command which allows you to convert various views of a 3D model into 2D drawings. I would imagine with as powerful as Solidworks is, there is something similar - it's just a matter of figuring out what it's called and/or what menu it's in.
Tim Eggleston
Banks High School
Banks, OR
Arc Pro 4800
PowerMax 45XP
Mach 3, SheetCam
Inkscape, Rhino 3D
Return to “Autodesk AutoCAD”
