I have a plasmacam and was wondering if there is a program or a way to switch a plasmacam file which would be ade on design Edge to just a normal dxf so that it can be opened without design Edge are there any programs that are downloadable that are able to do that
Also was wondering about a program that can modify font I have a lot of projects that people want font in a circle around a design and I'm having to do it on design Edge by hand each letter
File conversion and software
Re: File conversion and software
Designedge will do all of that if you have advanced software. Now would be a good time to upgrade, they are having a 20% software sale for the next few weeks.
PlasmaCam DHC2
Hypertherm Powermax 65
Millermatic 211 MIG Welder
- rdj357
As ICM says, upgrading to Advanced Design is 20% off right now and with that you could export any drawing as a DXF. It would also allow you to fit text to a path (closed or open).elky_1965_02 wrote:I have a plasmacam and was wondering if there is a program or a way to switch a plasmacam file which would be ade on design Edge to just a normal dxf so that it can be opened without design Edge are there any programs that are downloadable that are able to do that
If that's not an option for your budget you can use free Inkscape to work with your files, always save them as DXF and just use DesignEdge to import those DXF files to create cut paths and cut them.
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
