a little help with bobcad
Post BobCAD related questions and tips in this topic.
mmmetal
Post by mmmetal » Fri Dec 08, 2017 5:57 pm
I appreciate all that I have learned and the information thats presented on this site, it's been a huge help to people like me getting started in this field. Now if i could get a (I hope) a simple problem solved. I have been using Bobcad V26 to do my drawings and for some reason, I lost a lot of my icons that go accross the top of the screen and I can't find a way to get them back. I realize this may not be the correct section for this but I'm desperate to get them back quickly. Any help would be greatly appreciated.
sbest1
Re: a little help with bobcad
Post by sbest1 » Sat Dec 09, 2017 11:05 am
Not too sure, but in other programs it's usually because you have to click on the View drop down menu and hit toolbar so that a checkmark is beside it.
Hope this helps
Post by plasmanewbie » Sat Dec 09, 2017 12:01 pm
This has worked for me in the past
Hold the "Alt" key and press the "F" key, Now you should see the "Menu Bar" at the top.
Now right-click on "Menu Bar"and select elect the option "Menu Bar" and it should stay in view.
Hope this works for you.
claddagh
Post by claddagh » Sat Dec 09, 2017 12:10 pm
Google the topic!
ggeh
Post by ggeh » Wed Feb 07, 2018 6:17 pm
Right click on preferences, on the drop down starting with file look to see if there is any that are not checked. If they are not checked they wont show up. if you click on them and a check is in front of them they should reappear.
As sbest1 said you can also right click on view and then check the ones you want and they should appear.
Return to “BobCAD”
Easyscriber engrave attachment for Hypertherm plasma cutters.
