Harbor freight air dryer
Share tips and tricks you know of in this forum. Plasma cutting, material handling, metal finishing, marketing, or anything that you feel is helpful.
gaolista
Post by gaolista » Sat Oct 07, 2017 7:53 pm
We installed an air dryer from harbor freight and don't seem to have any better results. Our last trap before the plasma cutter is still turning deccident balls pink. Their isn't anything in the trap on the back of the plasma cutter but our cuts aren't piercing throughout the entire operation. Also the rate at which the balls are turning pink are the same as before we installed the air dryer. Anyway, if there are any of you out there that use the harbor freight dryer and can look at the photo to confirm my gauge is reading correctly that would be great. Thanks for the help.
little blue choo
Re: Harbor freight air dryer
Post by little blue choo » Sat Oct 07, 2017 10:18 pm
Mine works like a charm and runs at about 30 PSI low side pressure. Same as in your picture.
Rick
Rick
Arclight 9600 4x8 table
gaolista
Post by gaolista » Sun Oct 08, 2017 2:29 pm
little blue choo wrote:Mine works like a charm and runs at about 30 PSI low side pressure. Same as in your picture.
Rick
Ok, thanks for the reply.
I'll have to figure out why I still have so much moisture between the it dryer and my plasma cutter.
Just using 3/8 hose, do you think I need to be using pipe?
Thanks again for the help
Dana gear
Post by Dana gear » Tue Nov 28, 2017 5:37 pm
Depends where you are at in the world, Death Valley no humidity ,Hawaii lots of humidity.
Our shop is in Northern California, in the winter high humidity, we run automatic tank drains on all our compressors, you would be surprised how much water these guys blow off in a day. From there a couple of standard water traps and then in the CNC shops where we use Hankison coalescing moisture/oil removel filters fallowed by Hankison air driers and Motorgard air filters, may be over kill but our air is drier then a pop corn fart.
tnbndr
Post by tnbndr » Wed Nov 29, 2017 4:38 pm
Your problem may not be dry air but loss of air pressure during operation.
LDR 4x8, Scribe, DTHCIV
PM45
Miller 211
RW 390E Slip Roll
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
ggeh
Post by ggeh » Wed Aug 15, 2018 8:07 am
Rick
I have hf air drier to and the water trap inside the the unit never worked from the very beginning. I took out the float valve and and ran a drain hose from the bottom of the trap to an electric solenoid drain valve that has an adjustable timer and cycle length on it. no more water in my lines. I all so used 1/2 inch pipe on mine and it flows fine.
ForceDesigns
Post by ForceDesigns » Wed Dec 12, 2018 12:56 pm
gaolista, did you ever solve this issue? Was it the water trap as suggested by ggeh?
Home Built 4x4 CNC Plasma Table
Ethernet Smoothstepper
C25 BOB
Proma 150 THC
Razorcut 45 with IPT-60 Machine Torch
Software: Mach3 and Sheetcam, Inventor 2019 for serious design work and Inkscape for signs
tothwelding
Post by tothwelding » Sun Dec 23, 2018 1:49 pm
I have this same drier and im in florida where the humidity is real bad. I have had such a hard time keeping water out of my lines and once I put this drier in I have zero water issues. Ran a rubber 1/2in hydraulic hose from compressor to drier and another from drier to extra air tank. I also made 2 12in drops with valves right out of the compressor to a filter then the rubber hydraulic line. This way the heat from the metal pipe doesn't travel to the drier. Compressor will get hot if it runs a lot and the heat will travel if you don't isolate it. Heat causes the moisture
Users browsing this forum: No registered users and 0 guests
