need help with lnes
need help with lnes
First off, Thanks in advance. I found this sign and I am trying to make it for my friends house warming. I am including the original dxf as well as what I have so far. I am wanting to make it like the dxf on the right in the original where all the inner cuts are a "loop" if you will. I am having trouble because I keep confusing myself as to what should be a loop and what shouldnt, where to start, etc. Any help is appreciated and I am more than willing to pay if you should choose to complete it. It will be worth it to see the smile on my buddies face! Again, Thank you!
Re: need help with lnes
Wasn't planning on doing the entire file but I do conversions for pay if you wanted to go that route. I just joined the outside and you had a whole lot of lines not joined together. Try using whatever snaps your software has and see if that helps.
- Attachments
- Bobby R32.dxf
- (735.92 KiB) Downloaded 85 times
PlasmaCam DHC2
Hypertherm Powermax 65
Millermatic 211 MIG Welder
- Gamelord
- 4.5 Star Member
You had a couple open nodes that were messing with you.
I find that it is easier to see where the issue may be if I color it in. If it doesn't fill then I know I have something open.
This should help.
This should help.
- Attachments
- nissan.svg
- (120.74 KiB) Downloaded 82 times
- nissan.cdr
- (184.18 KiB) Downloaded 79 times
- nissan.jpg (129.3 KiB) Viewed 3623 times
Torchmate CAD
Torchmate CAD
Thank you guys for the responses. However I am trying to make the car black or solid and have the details such as the bumper lines, door edges, windows, etc negative or fall through like the original rat rod file. In order to do that I need to add parallel lines and connect them with loops such as shown here as a sketched in with free hand lines.
- Gamelord
- 4.5 Star Member
First you are going to have to attach all the drop out pieces (like you have done in the first pic you posted). Then, instead of trying to draw each line, select the line you want to edit and then use the contour tool. That should do it for you.
Torchmate CAD
Torchmate CAD
I. Not seeing that tool on my bobcad cam
- Gamelord
- 4.5 Star Member
That is in Corel Draw. I am sorry, thought you were using Inkscape which is usually quite similar. Have no idea about Bobcam or if it has that capability. Can't help you there.
Torchmate CAD
Torchmate CAD
