Corel X5 Node Help Please
Corel Draw Graphics Suite related questions and tips can be posted to this topic.
sbest1
Post by sbest1 » Sun Mar 26, 2017 12:38 pm
Hi. I've spent numerous hours looking through the help here. Thanks to Gamelords tutorial I've learned the tracing and how to reduce the nodes. The problem is that after I've exported the trace in dxf with the nodes reduced and I re-import the dxf, it has lots of nodes again and doesn't look like the node reduction saved. I'm wondering if I have a setting wrong somewhere. Do I export as an enhanced image or wireframe? I also can't seem to find where it tells me the number of nodes other than my original trace. Can someone steer me in the right direction please? Attached is an example.
Nodes.dxf
(556.07 KiB) Downloaded 19 times
Gamelord
Re: Corel X5 Node Help Please
Post by Gamelord » Sun Mar 26, 2017 1:31 pm
The problem is the exporting and re-importing, when you import the file from DXF to CDR (corel's format) it adds the nodes back in. Also check the way you are exporting the file, some formats will not export the splines and curves correctly and therefore will add in the nodes to make the curve look right. if it is adding the nodes in when you import into your cutting software, try exporting out in some different autocad formats to see if that will make it better.
Torchmate CAD
sbest1
Post by sbest1 » Sun Mar 26, 2017 6:51 pm
Thanks Gamelord. I tried that and my cutting software will only recognize the older formats. That is why I usually use EPS format. Can you advise me as to where I can see the number of nodes? Thanks for your help.
