PM65 Error Code
Discussion on 0-30 fault codes
rwskinner
PM65 Error Code
Post by rwskinner »
My fairly new (less than 6 months) Hypertherm PM65 had a code of 0-99 when I powered it on a couple days ago.
I cycled the power and the code cleared and all was fine.
Should I be worried? Internal System faults typically don't get better with time, but it may be very hard to diagnose unless the code appears more frequently. I just would dislike the send it in and a few weeks getting back with no problems found and get stuck in that loop.
rwskinner
Re: PM65 Error Code
Post by rwskinner »
Luckily it hasn't came back but I also haven't cut too much lately.
I was hoping Jim would chime in. It's odd that it only showed up once and hasn't been back.
I guess I will keep cutting until she quits.
Richard
ovrrdrive
Re: PM65 Error Code
Post by ovrrdrive »
I wouldn't be happy about that one...
Warning/Fault codes
(refer to operator manual)
0-12 Low input gas pressure: warning
0-13 AC input unstable: warning
0-19 Power board hardware protection
0-20 Low gas pressure
0-21 Gas flow lost while cutting
0-22 No gas input
0-30 Torch consumables stuck
0-32 End of consumable life
0-40 Over temperature
0-50 Retaining cap off
0-51 Start/trigger signal on at power up
0-52 Torch not connected
0-60 AC input voltage error
0-61 AC input unstable: shutdown
0-98 Internal communication failure
0-99 System hardware fault – service required
I'd definitely stick around until Jim comments on it.
gamble
Re: PM65 Error Code
Post by gamble »
Under warranty? Maybe they can load test it and see if it happens again
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
tcaudle
Re: PM65 Error Code
Post by tcaudle »
I have seen that from plasma dust. Open it up and gently blow it out. Getting a fault one time in 6 months and nothing since does not sound like a potential problem. Sometimes processors can do funny things when they are started. I would be a lot more concerned if it happened during a cut or just sitting with the power on.
Return to “0-99 fault Code”
