Lantern Shadow Light
Michmetalman posted a file of an old lantern under a previous post titled "Old Lantern Needed" (Thanks Mich!). It had the potential to make a nice candle shadow light. So here is what I came up with. This is quick and dirty but I am sure some of you metal geniuses can take it and run with it. You can use a votive candle and glass or a small glass chimney. Both will fit in the same ring. Sorry it was not dark enough for a better lighted picture but you get the idea....................RK
- 1MORECUT
Re: Lantern Shadow Light
Nice Job. Thanks for the file.
John
John
very nice Thanks
Hypertherm Powermax 85
Candcnc Electronics
Mach3
SheetcamTNG
Aspire
Candcnc Electronics
Mach3
SheetcamTNG
Aspire
Nice! I use mine pretty much the same way by putting a votive holder behind it.
Awesome!
Great idea thanks
very cool
I am really liken this item. thanks for sharing.
PlasmaRoute "DO NOT BUY there Plasma table from this company NO Support"
Thermal Dynamics A-60
ArtCam
Sheet Cam
Mach3
Refrigerator dry Air
Charlotte,NC
https://www.facebook.com/pages/ACSD-Art ... 90?fref=ts
ArtCam
Sheet Cam
Mach3
Charlotte,NC
Gorgeous work!!!!
Brew Worx.
Blue Frog Metal Works
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
- hdfaster
LIKE IT! Thank you.
Thank you for the share!
Nice. Thanks for sharing. Can't wait to cut one. Will prolly use copper vein powder coat
One question, what did you use for the ring that the candle sits in?
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
PlasmaCam DHC2
MADE IN USA
Hi K D. I used a ring roller and 11G X 1/2" strap metal to make the ring. You can also just use bend tabs to center the candle holder as in the revised attached. If you are wary of a candle flame, you can use a puck light similar to the one at http://www.harborfreight.com/catalogsea ... uck+lights. Lowes or Home Depot has them also. The copper vein coating would be a great color!.......RK
- Nacs Fab
That is cool, thanks for the share!
G540 with LCTHC by candcnc
all built... by me...
Very nice!!Thanks for sharing!!
Great idea
Thanks for sharing
