10 inch portable camp grill
Here is a camp grill i drew up and cut out of I believe it's 12 gauge stainless. The idea for a portable grill is from this great website, however i did design this one. just in case someone thinks i stole there thunder The trout on the handle was also from a user on plasmaspider... so thanks a lot all of you!
5x10 Dynatorch High Definition plasma table. Cuttingshop drawing program. Sigmanest nesting program. Custom fabrication and powder coating.
Whatsoever thy hand findeth to do, do it with thy might Ecclesiastes 9:10
Re: 10 inch portable camp grill
well, I'll be... The pics didn't post. so i'm going to try it again...
so i guess i can't get the pictures to post. any help?
- Larry83301
Go right below the text box and you will see a tab named "attachments" click on it and then "add files" and then browse to find the picture you want and ADD it inline, OR you can also attach files by dragging and dropping them in the message box.lklassen331 wrote:so i guess i can't get the pictures to post. any help?
Larry83301 wrote:Go right below the text box and you will see a tab named "attachments" click on it and then "add files" and then browse to find the picture you want and ADD it inline, OR you can also attach files by dragging and dropping them in the message box.lklassen331 wrote:so i guess i can't get the pictures to post. any help?
thanks, Larry!
I did try that, but for some reason they refused to upload... so idk
- Larry83301
Could your file be to big? Or the wrong format, try JPG and see if it will work.
Larry83301 wrote:Could your file be to big? Or the wrong format, try JPG and see if it will work.
Too big of file I think. Thanks again for your help, Larry... I think it posted now.Larry83301 wrote:Could your file be to big? Or the wrong format, try JPG and see if it will work.
Pretty Sweet!!!
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
do you cook on that? from the pictures it looks like the grill top is pretty far from where the coals/wood would be. just curious!
Yes, actually we did cook some sausage on it the other night. The grate is about 9 inches above the bottom plate, and it's a small enough unit that the heat is fairly compact. actually cooks fairly fast! Only big enough for about 4 hamburger patties though.... I have the dxf if anyone gets interestednatewelding wrote:do you cook on that? from the pictures it looks like the grill top is pretty far from where the coals/wood would be. just curious!
that was my next question! I have a camping trip for the 4th and I was going to try and find one to make that's small enough, and BAM there you have one! I would greatly appreciate it if I could use your dxf
yes sir, not a problem. I'll post it for you... i did do a few modifications to the new one, as in an ash catching tray underneath, removable grate handle, and handles for the sides of the box...natewelding wrote:that was my next question! I have a camping trip for the 4th and I was going to try and find one to make that's small enough, and BAM there you have one! I would greatly appreciate it if I could use your dxf
here's the dxf. i believe the handles, and how they work, are self explanatory And how it fits together...
- Attachments
- fire box complete with ash catch tray.DXF
- (153.35 KiB) Downloaded 167 times
there is only one corner that is loose enough to connect when the bottom plates are in. here's a couple pictures to show...
how do i download file for grill?
what are the 4 holes on the top of the 2 sides? I see the 3 extra holes for the ash catcher, the rest looks pretty self explanatory.
natewelding wrote:what are the 4 holes on the top of the 2 sides? I see the 3 extra holes for the ash catcher, the rest looks pretty self explanatory.
The 4 holes on the sides are for the handles. Understandably the box gets really hot so i included removable handles so you can carry it without burning yourself... here's a couple pics of the finished product. It kind of shows how the handles are bent to work..
