I am in need of a Cut Chart for a PowerMax 85, I'm gonna be cutting some 3/4" AR 400 soon and I want a ball park of where to start on settings instead of following the SWAG theory (Scientific Wild A$$ Guess)
Thanks!!!
Few problems in life can't be solved with the generous application of a cutting torch and a taco truck.... or something like that.....
- WyoGreen
Re: Cut Chart for a PowerMax 85
I don't have an HT85, but there are cut charts in my HT45 manual. I would think there would also be cut charts in the HT85 manual.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Your operators manual has 20 pages of cut charts with detailed info: Material type and thickness, torch to work distance, consumable part numbers, amperage, pierce delay time, pierce height, best cut speed, fastest cut speed, arc voltage.
I suggest using the 85 amp shielded cut chart for mild steel.....the AR400 will cut fine with these specs. here is the chart as copied from the manual.
Thanks a million guys! Now if I can just find the manual...
The manuals and much more info can be downloaded from Hypertherm's website, too.
Enjoy
Paul
Enjoy
Paul
