Hello,
I have recently rebuilt my table using CandCNC & Precision Plasma parts and am just attempting my first cuts since getting everything going again. I have a Hypertherm Powermax 45
Before I ran any g-code, I could fire the torch manually using Mach3.
I went through SheetCam's tutorial to turn a .dxf into G-code, which all it is, is a small sign that says "PLASMA".
It started cutting with the "S", and did it just fine, and about halfway through the "A" the torch stop firing.
I looked over to the Hypertherm and it had a solid Amber fault light.
I tried a few more times to fire the torch, whether by code of manually with no luck. Also tried shutting everything down and bringing it back up.
After a few more attempts, the Amber fault light started blinking.
It's also worth noting that I had to undo the BurnTable voltage "mod" from the inside of the plasma cutter.
Any idea what this could be? I'm extremely anxious as Ive had the BurnTable since last year and finally rebuilt everything with quality stuff so its been a long time coming!
Solid, then blinking Amber fault light?
http://www.facebook.com/WinterFabrication
Matt
CandCNC Ethercut
Precision Plasma Gantry
Matt
CandCNC Ethercut
Re: Solid, then blinking Amber fault light?
The number of blinks that the amber fault light makes helps Hypertherm tech service to determine the issue. First, I would recommend disconnecting all wiring from the cnc machine, then try firing the torch by shorting the start input (if you have a machine torch connected this will be pins 3 and 4 on the CPC connector). This will verify if the issue is with machine wiring or an output from your cnc machine.
If the system acts the same with the CNC disconnected (flashing amber fault light) then you need to count the number of flashes and contact Hypertherm technical service.
Thanks Jim
Wish I was at home and not at work so I could count the flashes and call. Hopefully the customer service line won't be closed by the time I get home.
Matt
CandCNC Ethercut
Matt
CandCNC Ethercut
Before you get all hosed up. Check your grounds usually when this happens out of the blue I forgot to hook up the ground.WinterFabrication wrote:Thanks Jim
Thanks. Grounds were my first check. I'll definitely recheck them though.cbassjr wrote:Before you get all hosed up. Check your grounds usually when this happens out of the blue I forgot to hook up the ground.
Matt
CandCNC Ethercut
Matt
CandCNC Ethercut
And, you can communicate via email with Hypertherm tech service....works after hours! I believe they staff the phones until 7PM Eastern time.
Jim Colt
Jim Colt
What SheetCAM POST are you using? The DTHCIV will refuse to fire the torch if you have lost communication to it from MACH3.WinterFabrication wrote:Hello,
Can you still fire the torch from the screen button?
I am not sure what the light means but one thing a torch won't handle is if the torch is fired (active) when you power it up.
You did go though the manual check list to test the DTHC (?) The DTHCIV tuning procedure in the Hub admin is critical to do before your first series of tests.
Its important to do things in the right sequence because you can blow consumables by just loading a file and hitting the run button before you do the dry run and manual cuts.
I called Hypertherm Tech Support. Just to clarify things incase anyone else is following, the blinking LED that you need to count is on the inside of the unit.
I ended up dropping it off at a local welding supply place so it can be sent off for warranty repair.
Matt
CandCNC Ethercut
Matt
CandCNC Ethercut
