Hi does anyone have a dxf of a font that can be cut and will hold the center of the O's ect.
thanks
Wanda
Fonts
Re: Fonts
Wanda, I have used many fonts that are preinstalled in Windows, you will find them in CorelDraw or whichever editing software you use. You just need to think about what part will fall out and make a simple break in the lines to stop cutting, make sure you rejoin the lines after you erase or cut away the piece. Also keep in mind, on Plasma, thinner fonts will burn out in spots. It's really trial and error, but you will find your favorite ones to use. Hope this helps you.
Michelle
Michelle
Re: Fonts
Here is one for ya !
- trucks1948
Re: Fonts
Try this web site and look for stencil fonts 1.0 it turns most fonts into cuttable font.Jim ----cadkas.com
