Registered sheet cam and this happend
andyn08
Post by andyn08 »
All of my cuts were coming out perfectly then I registered sheet cam and this happend. checked all of my mach3 settings for motors and they are all still good. Could registering have anything to do with it? I have included the dxf and tap files. I had to rename the tap file to dxf to upload
tapfilerenametodottap.dxf
(2.8 KiB) Downloaded 65 times
topbeefscaleddown.dxf
(88.87 KiB) Downloaded 68 times
Thank You
CNCCAJUN
Re: Registered sheet cam and this happend
Post by CNCCAJUN »
Did you reload your machine specific profile?
I know I had to get the specific profile for my machine.
If you are running Mach 3 not sure if that applies . . .
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
andyn08
Post by andyn08 »
well it so happens that when i told myself i need to save all my settings once i had everything setup perfectly i didn't. I just built this table to go along with my plasmacam so the settings were all custom to work with my setup. thank you
WyoGreen
Post by WyoGreen »
I took a look at your dxf. I first opened it with CamBam, and it looked ok, although it had an extra invisible layer. I exported it to dxf's, both with and without the extra layer. It made no difference when I imported the dxfs into sheetcam. If I import it in as metric, the dxf has the center lines of the holes on it. (it's also very small) If I import it in as inches, the center lines are gone, and it's about 5.5 inches wide. I kinda wonder if it's those center lines that are screwing up your hole spacing. Have you cut out this same dxf before you registered your Sheetcam?
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
mike 1948
Post by mike 1948 »
I looked at the dxf file in Aspire and all the vectors were open. I closed them and have attached the file. It seemed to import into Sheetcam and generate a good tool path either way. There was a layer though.
Mike
closed topbeefscaleddown.dxf
(9.51 KiB) Downloaded 70 times
Return to “SheetCam”
