It is currently Mon Oct 22, 2018 10:34 am
More 3D Metal Puzzle DXF Files
ericandmollie
Postby ericandmollie » Wed Feb 10, 2010 11:46 am
Here is a few more 3D puzzle designs to keep the kids happy. I have a good size collection of these puzzle in DXF format. I have touched these up, and scaled them to 16ga (.060) material. Hope you all like...
Dragon_Puzzle.DXF
Eagle_Puzzle.DXF
Ceratopsia_Puzzle.DXF
Butterfly_Puzzle.DXF
Ant_Puzzle.DXF
ericandmollie
Re: More 3D Metal Puzzles
Postby ericandmollie » Wed Feb 10, 2010 11:52 am
More....
Primate_Puzzle.DXF
Helicopter_Puzzle.DXF
Fly_Puzzle.DXF
elkriverfab
Postby elkriverfab » Wed Feb 10, 2010 3:27 pm
These look great!
Do you have any photos of the pieces put together?
Shawn.
Postby plasmajoe » Wed Feb 10, 2010 3:56 pm
Awesome!!! Thanks for sharing. Do you have pictures of these per chance?
ericandmollie
Postby ericandmollie » Wed Feb 10, 2010 4:53 pm
Here are some pics that I pulled off internet...
WTFChuck
Postby WTFChuck » Wed Feb 10, 2010 8:38 pm
I can't wait to cut these out!! Thank you! What is the best size to cut this at? Thank you agian!
WTFChuck
ericandmollie
Postby ericandmollie » Thu Feb 11, 2010 1:18 pm
I have the notches scaled down to .060" material. If you want bigger material, then scale accordingly. For example...if you want to use .119" material, then you would have to divide .119 by .060 (.119/.060)=1.98. You then would want to scale image in all directions by 1.98. If you want to use .25 plywood, then you would scale by 4.16.
The reason I use 16 ga material, is that we have a lot of drops of that size, and its free!!!
Should I post some more puzzles?
ericandmollie
Postby ericandmollie » Thu Feb 11, 2010 2:03 pm
More....
SaberTooth_Puzzle.DXF
Pteranadon_Puzzle.DXF
Mammoth_Puzzle.DXF
F15_Puzzle.DXF
fitzy
Postby fitzy » Sun Feb 14, 2010 7:33 pm
awesome job thanks for sharing my kids are going to love these
-fitzy-
It ain't braggen if you can back it up!
Chopper John
Postby Chopper John » Tue Feb 16, 2010 9:05 pm
A Spider to add.
Chopper John
Mad City Cycles, Inc.
mossie
Postby mossie » Thu Feb 18, 2010 2:23 pm
Hi John these puzzels are fenomenal thank you for these puzzels,do you have more or can you teach how to make them from the wooden templets you can buy.
I am very intrested to able to draw these puzzel.
Mossie
a newby
38 Special
Postby 38 Special » Wed Sep 08, 2010 7:09 pm
Pic of last spider:
All these are great.
Patrick Waite
Postby Patrick Waite » Wed Sep 08, 2010 7:50 pm
I could use the Buffalo Bison one if you have the DXF file for that one lol. Thank for all the files. They are awsome file. When I get a chance I would like to cut all of them.
Patrick
Patrick
Creedo16
Postby Creedo16 » Tue Sep 28, 2010 2:05 pm
I love these puzzles,,,,
my problem, is with my torches i have a minimum of 30 amp torch, high definition and the kerf width is around .060 if i remember correctly.
The dragon puzzle for instance has corner reliefs in each slot that are only .020" dia. the math does not work and my controller destroys the part when it tres to send them over for cutting.
how do i fix this?
Compnerd88
Postby Compnerd88 » Tue Sep 28, 2010 4:16 pm
My Waterjet has this same issue as the Kurf is around .040". The small radius' confuse the system and when it tries to cut it, the cut is all blown out at that location. I solved my problem by doing straight point corners....just let the jet create the radius if that makes sense.
-Logan
Creedo16
Postby Creedo16 » Fri Oct 01, 2010 9:23 am
So i need to load and edit the file then to remove all those coner reliefs? im not very cad efficient.
also with the slot sizes and my kerf width i figure i have to scale it up just over 4 times, I then can use 1/4 material and the slots will be 1/4 in width.
DARRYL21270
Postby DARRYL21270 » Fri Oct 01, 2010 12:41 pm
Thanks for all the 3d files but my question is, how the hell does it all go together are the pieces numbered or is that something we have to figure out on our own !!!!!!!!
ckhong
Postby ckhong » Tue Oct 11, 2011 5:46 am
Hi, how to download?
Postby plasmajoe » Tue Oct 11, 2011 7:42 am
ckhong wrote:Hi, how to download?
You have to become a Contributing Member, you will then have your name changed to purple then download all you want.
Postby metalart » Tue Oct 11, 2011 12:36 pm
Are there pictures of the Mammoth, Saber tooth, Pteranadon & F15 completed and if there are could you post them?
Thanks.
Chopper John
Postby Chopper John » Tue Oct 11, 2011 2:01 pm
This is a F15 I did awhile back. It's the only picture I can find right now but I will look some more.
Chopper John
Postby BrianMick » Tue Oct 11, 2011 2:34 pm
Chopper John wrote:This is a F15 I did awhile back. It's the only picture I can find right now but I will look some more.
that raptor is awsome, I would love the file If you have it
Chopper John
Postby Chopper John » Tue Oct 11, 2011 3:52 pm
Here you go Brian.
Reason: sample pic
Chopper John
Dawgonhawg
Postby Dawgonhawg » Tue Oct 11, 2011 4:29 pm
WOW thanks for sharing.
Postby BrianMick » Wed Oct 12, 2011 9:49 am
That is awsome chopper john thanks
Users browsing this forum: No registered users and 22 guests
