Home Made Air Dryer Idea
All topics related to compressed air supply.
Complete_Loser
Post by Complete_Loser »
This Air Dryer forum doesnt have an option for "New Topic" so i will just post here for now.
I have an idea for an air dryer. But not sure if it will work.
I was thinking of getting an A/C window unit and plumbing my copper airline into its cooling radiator. And down stream have an auto water blow off valve.
This would be much cheaper than me buying a refer air dryer, yet would be the same concept (i think).
You want it done cheap and fast, it wont be right.
You want it done right and fast, it wont be cheap.
You want it done right and cheap.., come back in a year..
AnotherDano
Re: Home Made Air Dryer Idea
Post by AnotherDano »
Too much plumbing and provisions for venting the hot exhaust.
Small refrigerators are cheap - dormroom size.
Run your air into a spool of copper tubing inside the unit. All it would take is a couple of quick-disconnects running to the outside of the unit and a long coil of tubing. Put a water seperator at the outlet and plug it in.
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
itsnotlevel
Post by itsnotlevel »
One idea I found...........pretty nice actually, as long as you don't mind buying ice.....could act as a beer cooler simultaneously....
:::Paul Wilson:::
Stay Gold!
CPK_Jim
Post by CPK_Jim »
Yes, this concept works!!!!!!!!!!! Check out my post titled cheap homebrew air dryer. The copper tubing is more eficient than the plastic line I used but, the plastic seems to work fine. I have not had a drop of water in my lines since installing it. I used the plastic because I already had a bunch of it lying around and i was looking to prove the concept on the cheap.
As for the air conditioner idea, it would use alot more power and be harder to fabricate than using a fridge.
Jim
Rokitman
Post by Rokitman »
How much copper tubing would you need to put in the frig for it to work. Where I work we coil bundle for small hot water heaters. I could get a pretty big copper coil drill some holes the frig and pipe it up and be all set to go.
Would i need to put a filter on the airline to help out.
Patrick ny
AnotherDano
I think it works best if the coils were looped horizontally instead of vertically, like itsnotlevel has shown. I've seen quite a few built with the loops at 90 degrees to his.
With the verticle, moisture is being trapped at the bottom of each loop. With a top-down horizontal design, the moisture would all drain down by gravity.
Just a suggestion.
Dano Roberts
Return to “Air Dryers, Air Filters, Air Compressors, Etc.”
