Mach 3 license install
kcarpenter12
Post by kcarpenter12 »
How do I put the license I have for Mach 3 on my computer so I can use the full version it says demo right now and every thing works but the plasma won't start or stop . Thanks
beefy
4.5 Star Member
4.5 Star Member
Re: Mach 3 license install
Post by beefy »
Just paste it in the main Mach folder.
Don't CUT and paste, COPY and paste, so you don't delete it from wherever you keep it.
Don't do it while Mach is running because Mach may need a fresh start to recognise the license.
I checked the Mach3 manual I have and searched for the word license. It doesn't actually tell you anywhere how to install the license.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
pertneer
Post by pertneer »
Shut down Mach 3. Put it in the main directory where Mach3 is installed. restart Mach3. should be taken care of.
Always keep a copy of it on a different computer or flash drive. The more the better. Less chance of loosing it in case of a computer death....
4'x8' CNC Plasma w/Water Table Running a Powermax 65 :D
CandCNC, Mach3, SheetCam, Millwrite Plasma V6
After you put it in the Mach 3 folder and restart mach you should see your license name on the top line of Mach.
like licensed to XXXXXXX your good to go then
Return to “Mach3 & Mach4 CNC”
