sheetcam cutting rules HELP
m79b01
Post by m79b01 »
I have the dev version of sheetcam and have some cutting rules setup. The post processer and all seems to work...but...my g-code output is putting the THC off on the same line as the next action.
Example:
N10 G00 X10
N20 S10 (THC OFF) Y20
N30 X11
ETC...
Not sure if this is an issue but it doesn't seem right. All input is appreciated.
Precision Plama LLC SDB 5x10
CandCNC
Hypertherm 65
Mach3
SheetCAM
the GIMP
inkscape
QCAD
https://www.facebook.com/burtonskustom
Sampson Jones
Re: sheetcam cutting rules HELP
Post by Sampson Jones »
Look up Les's u tube video on cutting rules , I use them with all work and it was easy to set up .
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
SeanP
Post by SeanP »
I'm not that good reading code to be honest but there was a bug at one stage where if you had 'show rule names in g-code' ticked it put that info on the same line as dthc on/off which caused some bother, Les cured that with a update though.
N0010 (Filename: ST7 dxf.tap)
N0020 (Post processor: MP3000-DTHCII-DCC+scriber6 SP 28-04-14.scpost)
N0030 (Date: 19/10/2014)
N0040 G21 (Units: Metric)
N0050 F1
N0060 G53 G90 G40
N0070 S10 (DTHC is off)
N0080 (Part: ST7 dxf)
N0090 (Operation: Outside Offset, OUTER_LOOP, T120: 12mm Steel)
N0100 (tool number: 120 Feedrate: 450)
N0110(Preset Volts: 114 )
N0120( Suggested Tip Size: 45 DTHC Delay: 6 sec )
N0130 S900
N0140 M22
N0150 S3114
N0160 M22
N0170 S560
N0180 M22
N0190 G00 X604.9076 Y-0.4250
N0200 Z3.8000
N0210 G28.1 Z3.00 F1000.0
N0220 G92 Z0.0
N0230 G00 Z2.1500
N0240 G92 Z0.0
N0250 G00 Z3.8000
N0260 M03
N0270 G04 P1
N0280 S20 (DTHC is on)
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Return to “SheetCam”
