Nautical Star
Nautical Star
Hi folks, Newbie needing a nautical star For a project I am doing. Anyone have one I can use ? Thanks
Re: Need Nautical Star
search compass rose, I don't know if thats the same or not
Best of luck!
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
Thanks for the share. Looks great!
John
Cut It Out
John
Cut It Out
Thanks For The Share
Someone feel free to throw up a picture of it. I made this file long ago and never cut it.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
here's a pic of something similar I did. Took the 3d star file a tweeked it with the compass rose file from here and come up with 3d compass rose/nautical star. This job does involve a little fabrication. Sorry for the poor pic and the dxf is on my shop computer if anyone wants it I can post later.
Mark
Mark
I just downloaded this file. It looks great. I imported it in to Corel and it was 714 inches a round. Is there a reason it was so big?
I not sure if this is why but I have seen different programs have different scales. So loading it into your program may cause it to be bigger then the original. I use turbo cad and when I load other DXF files posted here they can be very large. I put a select box around them and then reduce the box (with arrows on the outside corner) maybe a box is the wrong term.
acourtjester wrote:I not sure if this is why but I have seen different programs have different scales. So loading it into your program may cause it to be bigger then the original. I use turbo cad and when I load other DXF files posted here they can be very large. I put a select box around them and then reduce the box (with arrows on the outside corner) maybe a box is the wrong term.
Yeh... I didn't have a problem reducing the size. Just wondered if there was a reason it was so big. Thanks again for the file.
- Larry83301
A lot of the files import in METRIC. If a part seems like it's way to big just scale it by .03937. This will change it back to inch. Hope this works for you like it works for me. 714mm X .03937 = 28.11 inches
- 4.5 Star Member
Nice one, thanks David.
Keith.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
Well, your welcome, and it was a trace of an image I had drawn, so I never did scale it in autocad, I've never cut it.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
Plenty of welders
PowerMax 45
Lots of other toys
Really like this but it wont open in my autocad 2000?
any suggestions?
any suggestions?
weldor2005 wrote:Best of luck!
This one is one I designed for a client for some brackets with a Mariner theme...
the compass rose etc....
- tturanger
5 Points
MARK I WOULD LIKE TO TRY MY HAND AT IT IF U DON'T MIND SHARING THANKS RONhacnwac wrote:here's a pic of something similar I did. Took the 3d star file a tweeked it with the compass rose file from here and come up with 3d compass rose/nautical star. This job does involve a little fabrication. Sorry for the poor pic and the dxf is on my shop computer if anyone wants it I can post later.
Mark
Depends on how it was CREATED... if the software was setup for "Unit=mm" then the image will be scaled in so many "Units" and that unit of measure is a mm... if it was scaled in "Unit=Inch" then it is scaled to 25.4 mm or x units or x inches... in sheetcam you can select metric or inch scaling.. I can take a DXF and scale it easily in Inkscape or any CAD software to be exactly how many INCHES I want it to be...762frmafr wrote:acourtjester wrote:I not sure if this is why but I have seen different programs have different scales. So loading it into your program may cause it to be bigger then the original. I use turbo cad and when I load other DXF files posted here they can be very large. I put a select box around them and then reduce the box (with arrows on the outside corner) maybe a box is the wrong term.
A lot of drawings I get from Clients are not scaled per se' but they are set as "Units=*" or wildcard... meaning that you can set it to whatever unit of measure you want... but it is not set in the file. so if I open it in CAD it can be tiny... but I can blow it up as big as I please without losing definition but if I open it in Sheetcam on inch it is only about as large as a football stadium, if I open it in metric it is only about the size of a walmart parking lot...
Re: Nautical Star
This is my first posting in this section so hopefully it works for everyone. I've had a few people asking for this so I might as well post for everyone. The four larger points get bent approx 82-85 degrees and the smaller points get bent approx 75-77 degrees. I didn't include any of the round circles as that is fairly basic and can be made any size to suit.
Thanks Mark
Thanks Mark
Re: Nautical Star
THANKS FOR THE UP DATE ON UR POST THANKS TO ALL
