Anybody has this happen?
Usually, everything works fine, but:
Running a plasma, the THC is blinking green, but doesnt move the Z axis during cutting.
Close, restart mach3, it runs fine.
Its a pain, cause i start a piece, and dont know if it works or not...
The voltage goes waaay out of parameters, and yes, i pressed enter after entering voltage.
Is there a trick, has anybody had that experience?
Thank you
thc in mach3
Re: thc in mach3
IF your upper fault limit is hit in the cut profile it will stop THC from moving.
Re: thc in mach3
So if it hits the lower or upper limit, it will stop THC and continue cutting?
If so, that could be it.
Thank you
Thank you
Re: thc in mach3
Yes........No, You can set it to stop on fault in the cut profile, raise head and other options.
