Brighten Aluminum without dulling????
- 1fine79
Hey guys, has anyone got a good solution for brightening aluminum (like tread brite or mirror tread) without getting a dulled or milky finish? I just want brighten fairly new sheets that have been exposed to the elements but most of the alum cleaners that I have found just make things worse. Any ideas would be greatly appreciated. Thanks for sharing.
Wayne
Torchmate 2 self-built 5x10 w/ SS water table AVHC New
Hypertherm PM65 New
Miller Spectrum 2050 hand torch
Miller Syncrowave 250 DX
Millermatic 212 w/ spoolgun
Lincoln SP-250
JD squared Model 32 hyd.bender
Hypertherm PM65 New
Lincoln SP-250
- 1fine79
Re: Brighten Aluminum without dulling????
Really?....Nobody? Man I was hoping someone had the magic cure for my problem.
Oh well, back to the grind.
Man I still love this site!!!
Wayne
Hypertherm PM65 New
Lincoln SP-250
Hypertherm PM65 New
Lincoln SP-250
- Gamelord
- 4.5 Star Member
Aluminum dulls because of oxidation. The only way to brighten it up (that I know of) is to remove the oxidation via sanding or other methods. Once the raw-aluminum is exposed, it will once again begin to oxidize unless it is coated immediately with something like clear coat, powder, etc...
Aluminum oxide is nearly as strong as diamonds and is exceptionally difficult to remove once it gets on there. i don't know of any chemicals that will remove it from the aluminum without having to do some kind of polishing.
A Quick google search came up with this. I haven't used it or know of anyone who has..but this may be an option for you.
http://www.envirotechcoating.com/Aluma-Brite/
Also, Flitz polish works very good, but it is a polish and would take a bit of work to do a 4x8 sheet.
http://www.flitz.com/flitz-polish-paste/
Hope this helps.
Hope this helps.
Torchmate CAD
Torchmate CAD
Mothers Aluminum wheel polish and a car buffer??
