cant open dxf
Bigbird48
cant open dxf
Post by Bigbird48 »
I tried downloading a couple dxf files, I said open with coreldrawx5 corel opened but there was nothing there,
I use to be able to open them any ideas why not now??
MetalTorcher
Re: cant open dxf
Post by MetalTorcher »
Try using import function? Don't know for sure as I'm not totally familiar with Corel. Which files are you trying to open?
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
DXF
Re: cant open dxf
Post by DXF »
Open Corel
New file
import
Dave Hanks
Zippo
Re: cant open dxf
Post by Zippo »
I don't use corel, But I have noticed several time ,
That alot of the dxf are in metric and on mine it switch to standard.
Thus i get a a blank looking screen, However down in the corner is a tiny spec that if i enlarge it.. it the dxf
And at times it way of the screen either side.
The X and Y positioning are not always true between different programs.
So sometimes it there, you just have to search for it
Hope it helps you some
Gamelord
4.5 Star Member
4.5 Star Member
Re: cant open dxf
Post by Gamelord »
If you have the problem listed above, just press CTRL+A and it should select all, letting you know if there is an image there or not.
Torchmate CAD
tnbndr
Re: cant open dxf
Post by tnbndr »
In Autocad usually the image is just in outer space. A "ze" or zoom extents command usually brings the image into the screen.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
