I have usually been using HR sheet in my plasmacam, but I had to get some sheets of CRS the last time as the seller was out of HR.
Since using CRS it looks to me that the cuts seem a little better and sharper. Is it just my imagination or does CRS cut better?
Tony
Hot Rolled versus Cold Rolled for cuts?
- tony506
Eastern Canada
Hobby Shop/Business
PlasmaCam DHC2 with Design Edge
Hypertherm Powermax 65
Lincoln Mig
Everlast Tig & Stick
Hobby Shop/Business
Lincoln Mig
Re: Hot Rolled versus Cold Rolled for cuts?
This isn't the first time I've heard this. Others have said the same thing. Cold rolled cuts better.
Cold rolled costs more though.
I get scraps at a discont and end up paying less than HR steel though.
CR should be cheaper not more expensive since they do not have to reheat to roll it.
My prices here in Gary/Chicago area for CR are cheaper than HR.
Ted
Pcam DHC2 with the works
PM 30, 45 & 65
Corel Draw X6 - Adobe CS5
Ted
PM 30, 45 & 65
All I cut is cold rolled 14 gage and 12 gage. It is a little more expensive but will save you a lot of time and work on clean-up. I am amazed at how well it cuts with very little warpage. Been cutting stainless steel lately and it cuts great also.
Dave Hanks
Dave Hanks
- tony506
CR is more expensive here in eastern Canada, about $4.00 per 16g sheet more than HR.
Tony
Tony
Eastern Canada
Hobby Shop/Business
Lincoln Mig
Hobby Shop/Business
Lincoln Mig
CR steel is HR with the mill scale removed and rolled again to get a more precise product,therefore more price.If you try and bend CR rod in a hand bender it seems quite a bit stiffer than HR due to it being compacted by the second rolling.My 2 bits worth.
You're right. CR is a lot stronger than HR.OTHill wrote:CR steel is HR with the mill scale removed and rolled again to get a more precise product,therefore more price.If you try and bend CR rod in a hand bender it seems quite a bit stiffer than HR due to it being compacted by the second rolling.My 2 bits worth.
Dave Hanks
