plasma table antifreeze good news/bad news
abmagrum
Post by abmagrum »
the good news . I found it.
the bad news. CM-33 is $209.85 for a 5 gallon pail and it can ship UPS Ground
$30.00+ a gallon for 55 gallon barrel
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
urbnsr
Re: plasma table antifreeze good news/bad news
Post by urbnsr »
Thanks! Is there a mix ratio or should that be used without mixing?
Here might be an option - Possible not to be used when cutting aluminum, but not sure:
http://store.cyberweld.com/lowconan.html
Paul
abmagrum
Post by abmagrum »
Thanks.Paul
the cms is 30% for 10 degrees and you have to do a 5 gallon bucket to order .
do you know the ratio for youre brand ?
thanks
al
maybe there is hope :D
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
abmagrum
Post by abmagrum »
urbnsr wrote:Thanks! Is there a mix ratio or should that be used without mixing?
Paul
I haven't got a reply back from miller yet.
but from all my research I am pretty sure this is for engine driven machines.
not for table water.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
urbnsr
Post by urbnsr »
Sorry - Wasn't sure.
When I saw the "Plasma" on the jug, I must have just assumed.
abmagrum
Post by abmagrum »
no problem,
I just didn't want anyone trying it.
miller contacted me. the antifreeze is for engines only
thanks for trying. that was a hard search.
on to plan c .
heated bladder tank. the build should be easy . will post pictures next week . after are little snow storm.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
