Could someone tell me how to go about adding decorative designs to switch and outlet dxf files. What program or steps are required?
Thank You
Randy
electrical switch and cover plates
Metalworx Fabricators
ArcLight Dynamics
Hypertherm Powermax 45
ArcLight Dynamics
Re: electrical switch and cover plates
Basically any CAD program can do it, some easier than others. What are you using right now? With PlasmaCAM's DesignEdge I import the files I want to combine and then put them together. Corel and others can do the same thing, just may be a little different way of doing it. I'm most familiar with DesignEdge however.
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
What programs are you using?
PlasmaRoute CNC 4 x 4
Corel Draw X5
SheetCam
Baileigh 12 gauge 40 inch box brake
Corel Draw X5
SheetCam
want some examples ?
in the search above type outlet covers there is some files too
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
