sheet cam color meanings ?
abmagrum
Post by abmagrum »
red = outside cut
yellow = inside cut
white = ? ? :?
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
I Lean
Re: sheet cam color meanings ?
Post by I Lean »
White = open path. (single line, or there's a broken segment somewhere)
abmagrum
Post by abmagrum »
Thanks, I Lean
I reposted this file .
it shows up white in sheet cam.
would it cut ?
oh if you auto trace and there is a white line somewhere would it cut ?
thanks
al
NRA_cut.dxf
(195.37 KiB) Downloaded 87 times
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
I Lean
Post by I Lean »
It would cut, but there's a lot of weird stuff in there, especially in some of the lettering. It all shows up white because the lead-in is drawn in, and the path is broken where the lead-in is. If I were going to cut that, I'd probably go through and delete all the lead-ins, join the broken segments, and fix the weird lettering first. Time-consuming and tedious, but it would let you set up your cuts the normal way. :)
abmagrum
Post by abmagrum »
thanks, again :D
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
abmagrum
Post by abmagrum »
hi, I Lean or anyone who can answer this
will this cut ? the white line in the stocking . if not what needs to be done to fix it?
stocking.dxf
(11.26 KiB) Downloaded 95 times
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
I Lean
Post by I Lean »
That looks like it would cut nicely. If you set your operation up as an outside offset, it will by default use no offset on the open path at the top, and shouldn't apply a lead-in to that one either. It will just cut directly on that line, then move the the outside of the stocking. You'll likely see a little hole at the beginning of the cut from the pierce, and the rest will be a single-kerf-width line.
abmagrum
Post by abmagrum »
so I don't have to worry about the white line ? it doesn't have to be yellow ?
I read somewhere that white wouldn't cut.
I Lean
THANK YOU, for taking the time to help . it is much appreciated
al
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
Largemouthlou
Post by Largemouthlou »
It will cut, I cut free standing white lines all the time. Like lean said, it is the color for open path.. SC will asign it a start and not offset it.. You can change which end to start at if you prefer also..
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
abmagrum
Post by abmagrum »
I understand it now.
working to hard and to many hours.
off work in 2-3 weeks :D
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
Return to “SheetCam”
